ابحث في الدعم
Why is it when I log in in facebook , my saved passwords and email address will not appear?
  • 4 ردود
  • 18 have this problem
  • 21 views
  • آخر ردّ كتبه Albarr Muzarin
Well , ive save multiple accounts on my facebook , then when i try to log in , an option of my email address will appear ,, so its easy to log in .. After that , I cleared my browsing data , excluding the saved passwords .. Then tried to log in back ., but the options of email address will not appear anymore ,, but the save passwords will appear ..
How can I make it back?? Im tired of typing my email add again and again ..
Well , ive save multiple accounts on my facebook , then when i try to log in , an option of my email address will appear ,, so its easy to log in .. After that , I cleared my browsing data , excluding the saved passwords .. Then tried to log in back ., but the options of email address will not appear anymore ,, but the save passwords will appear .. How can I make it back?? Im tired of typing my email add again and again ..
الحل المُختار
Firefox wont show your username or email to secure your account . cause if someone use your device and tried to log in in facebook for example .. Then your accounts will appear and automatically log in .. So you need to type your email/username so that firefox knows that its you . :-)
Read this answer in context 👍 3
All Replies (4)
Control whether Firefox automatically fills in forms is normally what I would suggest, but is this question about a mobile device? Have you synced the preference to turn off this feature?
Modified by guigs
Firefox will only remember passwords for a specific domain. Facebook uses at least two different domains one for desktop users at https://www.facebook.com and one for mobile users at https://m.facebook.com it is not safe to assume that the www and the m server are controlled by the same entity. While it is true for the Facebook case it may not be true for other domains.
If you want the login on Firefox for Android to work visit https://m.facebook.com on your desktop Firefox, login and allow Firefox to remember the password at m.facebook.com
What about using a master password? Does it remember the email add and password??
الحل المُختار
